[O1] Proszę o analizę logów
  • aron55
    • 28
    Witam wszystkich, czarna stara I kombi.
  • Emef
    • 123
    VAG-COM Version: Release 311.2-N
    1o9lo0m-n6r12p-o9ko4x-kkjahh-568f
    Chassis Type: 1U - Skoda Octavia
    Scan: 01,02,03,08,15,17,19,35,46,56
    Address 01 -------------------------------------------------------
    Controller: 038 906 018 GN
    Component: 1,9l R4 EDC G300SG 2163
    Coding: 00002
    Shop #: WSC 05311
    5 Faults Found:
    17655 - Needle Lift Sensor (G80): Open or Short to Plus
    P1247 - 35-10 - - - Intermittent
    17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
    P1256 - 35-00 - -
    17958 - Charge Pressure: Control Deviation
    P1550 - 35-10 - - - Intermittent
    17552 - Mass Air Flow Sensor (G70): Open or Short to Ground
    P1144 - 35-10 - - - Intermittent
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-00 - -
    Readiness: N/A
    Address 03 -------------------------------------------------------
    Controller: 1J0 907 379 Q
    Component: ABS/EDS 20 IE CAN 0001
    Coding: 13304
    Shop #: WSC 31480
    No fault code found.
    Address 08 -------------------------------------------------------
    Controller: 1U1 907 044
    Component: CLIMATRONIC V 1.0.0
    Coding: 01000
    Shop #: WSC 31480
    1 Fault Found:
    00792 - A/C Pressure Switch (F129)
    35-00 - -
    Skipping Address 15-Airbags
    Address 17 -------------------------------------------------------
    Controller: 1U1 919 034 G
    Component: A4-KOMBIINSTR. VDO V22
    Coding: 00142
    Shop #: WSC 19411
    IMMO-IDENTNR: SKZ7Z0X0309188
    Address 46 -------------------------------------------------------
    Controller: 1J0 959 799 AH
    Component: 5T Zentral-SG Komf. 0001
    Coding: 04097
    Shop #: WSC 31480
    5 Faults Found:
    00953 - Interior Light Time limit
    25-10 - Unknown Switch Condition - Intermittent
    00928 - Locking Module for Central Locking: Front Driver Side (F220)
    27-00 - Implausible Signal
    00943 - Heated Exterior Mirror: Driver Side (Z4)
    35-00 - -
    00930 - Locking Module for Central Locking: Rear Left (F222)
    00931 - Locking Module for Central Locking: Rear Right (F223)
    End -------------------------------------------------------
    Najbardziej interesują mnie te związane z silnikiem.
    moja skodzinka : http://forum.octaviaclub.pl/viewtopi...er=asc&start=0
    • przemik
      • 1610
      Cos sie nie porozpinalo w instalacji.... ze tych bledow tyle ?
      Wszystkie wracają po skasowaniu ?
      Przemek
      DIAGNOSTYKA GRUPA VAG
      80 B3 Limo 1.6 TD SB
